Calipers: Single or Dual Pistons? | Ford Explorer Forums
Oldwolf
Cary, NC
2002 XLT, 4x4, 4.0 SOHC
I did a search on this topic but did not get any hits.
I need to install new brake pads on my 02 XLT 4x4 w/ heavy duty towing package. The parts list say pads for single cylinder calipers and two cylinder calipers are available.
How do I figure out which calipers I have?
Thanks!
You can usually tell by the shape of the caliper, there will be 2 round bulges on a 2 piston caliper and one round bulge on a single piston caliper. Or, you could unbolt a caloiper and remove the pads and see whether there are one or 2 pistons. My 2002 XLT has 2 piston calipers in the front and single piston in the rear, I'm pretty sure that this was the only setup that came on 2002-2005 explorers.
AFAIk, the '02 will have dual-piston calipers on the front. I could be mistaken though, so don't quote me on that.
I'll find out tonight when I change the pads. I bought the dual piston pads, so we will see.
I believe they're dual in the front, single in the back
Yep, mine are dual front, and single rear.
Changed our brakes today.. dual front, single rear. :thumbsup:
Brakes
Dual front,,,sigle rear. I need repair kits for my pistons but i have been uanble to find them. Can anybody tell me where to buy?
Thanks,
Temy
Thanks,
Temy
I think yours will be single piston since yours is a second generation.
Is the caliper leaking fluid or something? Cauz calipers are typically under $50 (after the core charge) so it might not be worth your time to rebuild the thing.
http://www.partsamerica.com/Product...1C&MfrPartNumber=184604&PartType=5003&PTSet=A
