Camber bushing help | Ford Explorer Forums
Camber bushing help
Bootless
1994 ford explorer 4x4
I installed a lift so no I'm trying to work on my camber but the dang bolts are pretty much froze up I tried a 4 foot cheater but no luck any tips
Hit em with a MAP gas flame. You can buy a Benz-O-Matic with an adjustable nozzle at a place like Lowes pretty cheap. You may have to heat cycle them a couple of times until they break loose.
Last resort, alignment shop, let them tackle it, you may be money and time ahead doing that.
Yeah that's what I figured we only have one shop here that is worth a dang probably going to have to wait till after trucks gone wild
Impact wrench?
The pinch bolt that holds the camber/caster adjuster in place? If youre having trouble getting that out the bushing itself is going to be a nightmare lol. Replace your ball joints while you're at it, because you're probably going to wreck the upper joints beating them with a hammer to get the adjuster out.
A decent air impact or GOOD cordless impact (i.e. milwaukee fuel, snap on, IR) should get the bolts out easily. Lots of heat and PB blaster wont hurt though.
