camber bushings | Ford Explorer Forums
camber bushings
jayzmann
victoria b.c
92 xlt 4x4
hi plan on doing ball joints and spindal bearings (thank's to ted j and glacier 991 for the how to's) plan on lifting the truck 2" to 4" in the future so should i change to adjustable camber bushings now or wait till i do the lift? thank's again for this forum your work is appreciated. J
The factory style bushings still allow for adjustment of caster/camber, but you have to use a different bushing for different amounts of adjustment if the ones that are on there aren't suitable anymore.
The bushings that are adjustable can be worth it if you mess with your alignment, or have a need for something other than fixed bushings where you just set it and forget it.
just curious what stock spec's are and thanks for the reply
i just put a 4in lift on my 93 x and was wondering how exactly i install the camber bushings
bushings
a bit of work i think you may have to pull the steering knuckle drive out old bushings note position before removing then install new bushing put it back together check the thread on ball joint replacment that will help you big time if you installed the lift yourself then this should be fairly easy to do i did mine {ball joints} never done that before it was quite easy with the help of this site and the how to on balljoints i love this place gonna become full member real soon this site saved me money and time
