How to: - Cams in Motion + Remove "Full Screen Not Available" black box - 2025+ only | Ford Explorer Forums
How to: Cams in Motion + Remove "Full Screen Not Available" black box - 2025+ only
Prefix for threads which are instructional.
Nightshade
FDRS & FORScan EXPERT
Alberta, Canada
2024 Ford Explorer ST
Good news for those with 2025+ Explorers (will be all trims). Those who are wanting to enable cameras at speed and are encountering the issue with the annoying black box in the middle of the screen that says "Full Screen Not Available", the changes below allows you to enable your cams while you're in drive and at any speed! All you have to do is press your camera button in the buttons row, right next to your volume knob and it'll work!
APIM -> 7D0-02-02 -> x..*-xxxx-xx--
(If your current value is 0 then change to 1, 2 change to 3, 4 change to 5, 6 change to 7) NOTE: Reboot APIM after the change.
**Always remember to make a backup of your APIM module before making any changes, just in case and to be safe.
--Cheers!
--Cheers!
Sorry if this is common knowledge but when you say Reboot the APIM. Are we talking a reboot using the power button and FFWD buttons for 10 seconds or using the "Service Functions" and "APIM Module Reset" within ForScan?
Edit* Does this only work for the rear camera and hitch camera? My front camera still shuts off at speed?
Thanks in advance.
