fast_dave
- June 6, 2005
- East Bay - Nor Cal / PRK
- '98 Spt 4.0 OHV 5 spd 4x4
Someone recommended removing the hood. I know removing the upper intake manifold will gain a bit more room, but man I'm dreading that again.
@Runnin'OnEmpty
For this particular repair, it's "top down" - just saying....
Mark where your hood hinges mate to the underside of the hood, & remove the 4 hood bolts. (2) People and 5 minutes total time, countless headaches saved.
If you choose not to remove the hood, your head will be in constant contact with the rear of the hood, pushing your face down into the rear of the engine, and thus you'll have only a few inches of field of vision or the area you're working on. The constant reminder of discomfort and the struggle to see will really wear on you...
You can choose to remove the upper intake, but if you remove the hood you won't need to do that. Seriously, the hood is 90% of what is in the way of this OHV repair that needs to be performed from literally the "top down." With the hood off, you can see everything you're working on with your own two eyes (and a lil' light).
Edited to add the following after I just had my Ex's hood open to check the oil: The other thing that is in the way is the ECU (computer) wire loom/bundle. Unscrew the one bolt that connects the wire loom/bundle to the ECU and bungee cord it out of the way.
Get a good quality step stool, do your stretching exercises & good luck!
Your Mileage May Vary -
