Can a shop screw up turning front rotors? (problem found)
I just replaced my front brake pads on my 2003 Xplor, had the rotors turned and now brake pedal pulsing badly. I did the work. I've done this many times on other vehicles and never had a problem.
Any thoughts before I pull the wheels off again?
Answer....................Yes they can.
To make a long story short, I found one of the rotors had been turned incorrectly thus causing worse brake pedal pulsing than before I started. Orielly's auto parts did this, but they did correct it. After re-turning the rotor, the brakes are smooth as silk. I found which rotor by pulling the tire, and looking from the top, down the backside of the rotor while turning it and could see the small air gap between pad and rotor appear and disappear.
