Tarpman
- September 12, 2008
- Escalon, CA.
- 03 Explorer XLT 4.0
I have to replace my upper control arms and inner and outer tie rod ends on my explorer. My question is because of time restraints, I really need to do the work and drive it for a couple of days before I can go and get an alignment done professionally. When I replace inner and outer tie rod ends if I make them the same length as the old is that good enough? Before I put the new control arms on if I measure from the inner edge of the wheels to somewhere on the frame and slide the control arm in or out until I get the measurement close to the same then tighten it down would that be good enough to drive it for a couple of days
