Roadblock1945
- June 14, 2011
- 2002 Explorer XLT
I have a 2002 V6 4.0 Explorer XLT. Knock on wood, I've NEVER had any major problems with it and it's sitting at 247,000+ miles.
The only thing I might consider above a normal wear issue was I started to get this hard bucking in the transmission but you guys helped me diagnose that as a solenoid pack. I bought a factory Ford one off ebay for $200.00 dollars and picked up a new drain plug, trans filter and fluid from my dealer and did it myself in the driveway. That was about 80,000 miles ago.
I replaced both rear wheel bearings last year. I had done the front ones a few years ago and they seem to still he holding up.
I just replaced both upper and lower ball joints on the front end about two weeks ago. I also did a full set of Monroe Quick Struts all the way around while I was in there. Actually that was kinda funny. I had put new rears on about 5 years ago because the back end bounced a lot but I was still on the OEM fronts at 247,000+ miles. I pulled the old 5 year old ones off because they started to squeak and took them back to Advance Auto, they warrantied them and gave me a new set for free. They had like 100,000+ miles on them! I also picked up a new set of fronts off Amazon hence the doing them all the way around.
OH did full pads and rotors while I was doing struts just a couple weeks ago!
I have some play in both inner tie rods. I have new ones sitting here. Thinking I may just do my outer tie rods too even though they don't have play, they are the factory originals. $22.00 dollars each on Amazon for MOOG's.
Both front sway bar link pins are snapped, found that when I did the ball joints so I have a new set of MOOG's here. $11.00 dollars each. Also bought MOOG sway bar bushings for $12.50. Going to do those tomorrow.
A/C is NICE cold, just refilled that.
Ummm yeah I mean it runs and I put about 500 miles a week on it. Just got new Firestone Destination A/T tires.
I do have a NASTY rattle in the engine bay. Sounds like it's coming from a timing chain? I hear it really bad around 2,500~3,500 RPM. It's been doing that since 117,000 miles though. I pretty much decided fixing those parts was out of my ability and I know you gotta pull the engine to do it so I figured drive it til it drops. Here I am at almost a quarter of a million miles!
I've never changed my factory hoses.
I've never changed my factory plug wires.
I've never done my fuel filter.
I've never changed my factory serpentine belt.
I did not flush my radiator until like 230,000 miles when the heat stopped working. I just never thought to do it. Oddly enough the inside of the hoses are coated with a rust like debris but but it doesn't seem to be affecting anything. Car doesn't over heat or anything. I think I probably NEED to get some type of coolant system cleaner and add it to the radiator and run it for 2 or 3 days, flush it and replace every hose that carries water but I'm almost worried that might do more harm that good. Thoughts?
Frankly I'm SHOCKED this SUV has held up as well as it has. I'm VERY impressed. When it goes, I'm planning to buy another Ford Explorer.
I'm really just wondering what you guys would do that this point? The stuff I just did wasn't that expensive. Two of those struts were free, the other two were $110 each. The ball joints were all between 22~28 dollars each. The tie rods were 21 each, sway bar pins, 11 each. I mean I got a couple hundred into it not counting normal stuff like tires.
At this mileage I don't want to drop hundreds into it but it lasted another 50k reliably and then I could just make it a weekend toy and boat hauler, I would retire it from normal driving. I'd like to get a new SUV within the next year or so.
It's late. I'm tired and rambling. Just looking for advice I guess!
Thanks!
Thanks!
