The truck:
-'84 Ford F-150 2WD 300 Straight 6 (4.9L for the metric folk)
-pretty sure the engine is strong, although I haven't put much time into it. I put new plugs,wires on it and a NOS Carter carb, but didn't adjust it. It seems to lack "get up and go" and has a horrible exhaust leak somewhere.
-the body has problems. The bed has been beat to h3ll, but I can pick up a replacement for a couple hundred bucks if need be. The worst part of the body trouble is in the cab floorboard where the driver's seat belt mounts. To put simply, there is no solid floor there.
I bought it ($350) simply to carry loads to the dump. All I have done to it is completely re-do the brake system (cylinders, calipers, drums, pads, shoes, mc, hoses, hard lines), put a fender on it, and basic engine tune-ups.
So, onto the questions. I have known guys that have owned the basic same rig, with the same engine, and used them to do a lot of towing of horses and hay and such. Is this type of truck even capable of towing a trailer with a 5000lb X on it? I always thought that when I got to the point of getting a tow rig, I would look into a F250 or similar rig, but is that POS F150 in my driveway capable of the task if I put the time/money into it? It doesn't have to be a "great" tow rig, just capable. Parts for this truck are easy to get, and cheap. Is it worth trying to make into a tow rig?
