can i remove rear prop | Ford Explorer Forums
carpcrew
lincolnshire
hi im trying to find my whining noise on my 4ltr 1998 auto explorer, i get the noise on load only and checked under car and only thing i could find was play in rear imput into rear diff, question is if i remove rear prop would it be ok to drive , im thinking if noise goes i will know if its diff or not cheers rob
What? Are you saying that you want to remove the driveshaft and use it like a front wheel drive in 4x4? I don't think I entirely understand...
yes! only to test the rear diff to see if its where the noise is coming from, i did the same on a freelander when transfer box went wrong, two completely different cars i know but theory the same, cheers rob
I guess it would be fine to take it up and down the street, but the rear axle is still going to be rolling, even though its not under any power.
DO NOT TRY THIS AT HOME!!!!
Even with the switch set to 4high or 4low, the transfer case lockup is still handled by the transfer case clutch coil. When you switch off the ignition, the coil loses power, and the transfer case unlocks. So, despite being in PARK, there will be nothing holding the truck in place and it can roll. Even locked in 4high or 4low, when the vehicle is stopped, the clutch goes to a minimum duty cycle. You could probably bypass it by using the brown wire mod to force the case to stay locked, but again, when it eventually runs the battery dead and the coil releases, the truck is free to roll.
Now, you *can* use the parking brake on a temporary basis for troubleshooting, but I would not recommend relying solely on the parking brake to hold the vehicle in place.
That being said, if you've got play in the pinion shaft, do not spend any more time playing with it. Get it to a competent driveline shop and have it rebuilt. The longer you wait, the more expensive the repairs are going to get.
Change the pinion bearings and call it a day...I can almost garuntee that's your issue.
AHA! Very good point! I wasn't even thinking that by losing the rear driveshaft, you loose park
