joshhemming
- August 15, 2011
- El Paso
- 93 Aerostar 2wd 3.0L
My right rear brake cylinder is leaking. I've seen some YouTube videos where they were able to (carefully) remove the cylinder on some non-Aerostars by just removing the wheel, drum and upper spring. Anyone know if there's enough clearance in the Aerostar brake assembly to pull the cylinder without taking the rest of the springs and shoes off?
Also, is the nut which secures the brake line to the back of the cylinder a Metric or an SAE? I don't have any of those special line wrenches and want to buy the right type.
