jabramson
- January 21, 2004
- Coconut Creek, Fl
- 98 Sport
The other day, the brake warning light started to briefly come on. Today I checked my fluid and it is a bit low so I assume the light is coming on when I turn corners and brake because it is so low and the sensor is letting me know it. The brakes seem to be working well in any case.
The reason I ask about replacing the master brake cylinder is because it appears I have a slow leak of fluid in the rear of it along the booster. There is a little bit of what appears to be fluid from the master brake cylinder as it is a little wet and grimy from dirt and grease right below the brake cylinder along the booster. That combined with the low fluid and no other locations showing fluid loss seems to be the leaky culprit.
Because of the fluid leak, does the whole master brake cylinder need replacing or is there a seal that can be purchased to fix this.
Thank you in advance for your help.
