Can I use Edelbrock IAS stock w/ 2" drop? | Ford Explorer Forums
Ross-N-Chicago
Elite Explorer<br><img src="/forums/images/stars4.
Chicago, IL
'91 XLT 2wd
I've got the IASs on the way and was thinking about getting Eibachs' 2" drop front coils and the 2" drop for the rears while adding some helpers. Will the IASs work with a 2" drop? I'm guessing they would but will wait to hear from the pros.
No, they are standard. Am I f*****??
I would return them and get the lowered models. I have them on my 99 that is dropped 1 3/4 and they are great.
Good luck.....
You're fine using the stock length ones, unless they bottom out before the springs bottom out, but I don't think they will. It is better to use the shorter ones though. Not only is the length correct, but the valving is different too.
Edelbrock doesn't make a shock for the 91-94s that are dropped. Now is 2" going to adversely affect the shock's performance? If yes than I will get the Exp. Express springs (no drop) and forget the block for the rear. If no effect than I will get Eibachs' 2" drop springs and 2" blocks for rear. Thanks...
