can my x tow a toyota 900 miles | Ford Explorer Forums
sajnaj
rockville in
91 xlt
ok i nead to tow i toyota form cinnatio ohio - rockville indiana about 900 miles round trip i was gogin to wrent a tow dolly does it got enough power to do the job for that long trip and the vehicle 1994 sr5 extended cab. if that wount do it i have a 1986 g20 conversion van "aka the beast" 3 inch exhaust all the way back 350 small block brand new but if i take that the gas is gogin to be about $$$150 round trip and that is a little pricy. or is there a service that could trans port it for me for cheap :burnout:
I'd tow it for you if you were in so cal. anywho, yes you can tow it. You might be better off renting a truck and trailer if you don't wan the wear and stress on your truck. What kind of terrain do you have to travel? You got a 4.0 w/ auto?
yea a auto with a 4.0 could it handle the load and i have a secondary oil cooler would that help alot
I'd use the van, I don't think the gas mileage will be much better if you're using your X. Plus then there's no worry about blowing the a4ld in your Ex.
i agree, the van is much better suited for it, too
ok the beast it is that thing is mean for a van and it can go thru some mud i was stuk in a feild with my explorer on a dolly behind me and it pulled its self out like nothing all the waiut makes it sink untill it grabs
pull it with the beast
ur just every where i think that i will
I'd definately use the van.
