Can the Cruise On/Off be Changed | Ford Explorer Forums
Kevin Kuiper
Eustis, Fla
96 XLT
Can the On/Off Button on the Steering Wheel be Changed?? Mine WORKS, but it is Broke Open... If it can be, does anyone have one????
Thanks All!!
Kevin
Thanks, What Key Word???
You may also try posting in the FSOT Forum here. Look through the forum for threads with people parting out '95-'97 Explorers. You will want the switches for both sides, with all the wiring, and the plug to avoid having to splice wires in.
eBay will also work. I got a new steering wheel, with the switches, off there for $25 a couple of years ago.
Thanks!! Yeap I found a Few.. I am also trying the Classified Here in this Forum... Wish Me Luck !!!
funny. when I bought my '91 X the ON key on the cruise was/is missing. Why the heck would that one Button break off? I gotta look for one too.
You don't need the wiring unless the plugs are broken off. These units have a receptical (looks like a bunch of straight wires) I've switched out both sides from my 95 to my 96. You can even take these buttons apart just remove the air bag then remove the 2 screws (each) unplug them, then GENTLY pry the rubber away from the plastic. Careful not to break the 2 tabs that hold the cricuit board in. I had to take mine apart to fix burnt out light bulbs.
Ford Parts Network has them new. $60. or so if I remember right.
