cj111
- January 4, 2014
- Alaska
- 1995 Ford Explorer Sport
Hi guys , I have a 1995 Ford Explorer Sport with 4.0 OHV and 4x4. I am in the point of reinstalling a valve body that is going to get the Transgo Shift kit(valve body update). I have also ordered a Sonnax Boost kit for increase line pressure but cannot decide if I should add this to the valve body. The reason for doing this is because someone rebuilt this trans not to long ago before we bought from the previous owner and the car has always shifted funny. The VB has a Transgo kit in already but the VB for the pressure valve has score marks, so I ordered the Sonnax kit 03k to repair this issue. Then after looking the unit over decided to get a VB from Cassadetrans( Electrical AdvantageInc). All my solenoids pass ohm test,including EPC,TCC. Gil at Transgo said that the kit from them is not calibrated for the Sonnax kit, but after reading several post here including Glacier991 it seems that they have been done. Maybe it is just that the kit I ordered from Sonnax is the higher pressure kit and not to OEM specs.I also found that the low/reverse servo spring is missing, is this some kind of additional trick?. What would be the pro's and con's of using a Sonnax Boost valve kit with higher line pressure and the Transgo Shift Kit together on a 4R55E valve body?.
