Can you EVEN drive on 33X12.5 on a stock truck ? | Ford Explorer Forums
jfman
Georgia
92 manual tranny
Ok here is my problem. My truck is a freakin rust bucket but I love it :thumbsup:
I realised that I dont have what it takes to lift it myself due to the extent of the rust taht is on my bone stock 4x4 explorer. My cousin has a shop and he will help me out puting the BL on along with 2in shackles and the TT.
THE PROBLEM: I'm in the southern US, he is in Canada. I am going there anyway for a wedding.
I cant drive on my old stock tires, they wont make it, I should have replaced them long ago but I was waiting on my lift so I did not buy tires for nothing.
So I have to make a 1500 mile road trip on 33's and the stock suspenion.
Is that event possible ?
I dont care if they rub while turning and all of that. I just wanna make it up there.
Can I drive on them ?
No
Could he cut the fenders like fo and take out those plastic wheel well things and do it?? That seems like it would be reasonable.
with a TT and shackels...maby.....but stock very doughtful.....but slap them on and see what happens...go to auto zone and get some 15$ shackels crank up the t-bars firsth though.
you could always remove your fenders and toss them in the back until you get there. :D
that would be friggin funny!!!
but that could work!
the problem is usually the rr sitls lower then the front....
I cant do a TT or a shackle because I dont own a blue wrench, otherwise, I would do everything here including the BL.
I bought my wheels and tires today. I'm picking them up at summit on friday, so I will try them on :confused: :D :roll: I could not find a better deal than them. Yoko's 33x12.5x15 mounted on 15x10 black steel wheel for $722. I doesnt hurt that I can save $100 on shipping by picking them up. :thumbsup:
If rolling on them is not possible. I will risk using my old strockers and carry the 33's as spares. Maybe they will work out back but not up front I fear. I dont have the plastic over my fenders, it's an XL explorer.
what is a blue wreck?
with a 15x10 rim there is no way in hell your fitting them without 4 or more inches or lift.
15x10 there is no way maby maby maby a 15x8
:D
Well see :D I'll post a picture :D
o0o boy i can see nothing good coming from this :fire: :D :fire:
edit: I reserve the right o use a rubber mallet and reshape my fenders to make it work :D :eek: :D
Seriously though I think i might be able to do shacles here and remove the front fenders. But I fear the look of the customs agent as I enter Canada with no front fenders :eek:
ahha you dont need a troch to do a TT you just jack up the front end spary some pb blaster on the bolts and turn away.
Not on my truck ! I tried
I have holes in the body big enough to fit your fist.
wut does the holes in the body have to do with doing a tt?
its 2 bolts that u tightn underneath the truck and thats it
u take a couple of measurments b4 and after and ur good
if u want to go takin a mallet to it by all means go ahead but i wouldnt b surprised if while hitn the fender, somethin else might go wrong!!
take off the front fenders...that may get you the 33's on in the front.
Can you get a used set of tires mounted for the drive? I would think you get something fairly cheap. At least cheaper than turning a tight corner and wrecking one of your new tires!
