backporch
- April 22, 2018
- Freehold NJ
- 2000 Explorer XLS
Hello forum members
I joined to get some help from Explorer experts and owners to help me get an Explorer running so that I can determine if this low mileage truck is a good candidate to supply its 4.0L OHV engine for my 1999 Ford Ranger.
I currently have a no crank situation which could be due to a number of conditions and I have found great resources already here. I am hoping I can rule out some more serious concerns that don't seem to bubble up to these lists.
I charged the battery using a trickle charger and after replacing this "charged" battery got to the point where it sounded like a groan which might have turned the engine slightly. Subsequent attempts no better than a click. The truck behaves strangely like there might be some electrical issues, but I really don't know battery health which could explain most. I also put a small jump starter on the battery and no luck. When I have used those in the past, they have worked wonders.
I am concerned with....
PATS: The key that I use mechanically turns the ignition and the unlock silences all blinking lights. I think that mean PATS has been satisfied, but wouldn't the car still crank even with a non-chipped key?
Engine Seized: The seller said that it was parked after a coolant loss that was not an overheat situation. Coolant on the driveway. I would like to mechanically spin the engine. There is not much room. I was condering taking off the fan if that can be done without removing the radiator to gain more room and putting a socket + breaker on the crank bolt. Turning clockwise?? should it take a great deal of effort to get the engine to rotate?
I realize there are many other things that would keep this from cranking like electrical issues, starter issues but I wanted to know that I have a chance of getting it going. Thanks for the help and for reading this long post.
