Can't remove broke antenna | Ford Explorer Forums
iamdestruktor
QUEENS, NY
2004 Explorer XLS Limited
Bought an after market antenna and it was fine until it broke in the car wash (shoulda seen that coming). Anyways, i tried removing the left over piece with pliers and it was very difficult to turn and after a lot of force, a top piece broke off and left me with what's in the picture. Now i don't know what to do to remove the rest. I've search the forums but nothing similar to my problem.
https://www.dropbox.com/s/q22wk09tf1vq6qk/2013-05-03 12.35.11.jpg
Right off the top of my head I'm thinking two quick options.
- Put a tiny weld on to something for a handle and then twist it out (not sure the material)
- Grab a new antenna wire from the junkyard - it can be disconnected and reconnected from behind the glovebox, and unmounted from the body from underneath the fender (take off the wheel well liner and poke your hand up)
Thanks, I actually went to a junkyard before this post and the guy immediately told me to go to the Pepboys down the road and get an antenna mount (or casing i can't remember). That didn't make sense to me, nor did they have such a thing in Pepboys. I'll try another junkyard. I also was thinking i'd try a spray that helps with rust but had second thoughts.
iamdestruktor, check your PM. I have sent the antenna removal instructions from my shop manuals. :):thumbsup:
