tpwarren
- May 5, 2006
- Houston, TX
- 2002 Mountaineer 4.0 AWD
I have a 2002 Mountaineer (4.0 AWD). I am have a rough idle all the time and decreased fuel economy and torque. I am getting NO engine codes so the dealerships are clueless. On rare occasions, it will die at the end of backing up. Now let me run through what I have done to try to fix the problem:
1. Got injectors cleaned. This had no effect and eventually the problem got a bit worse.
2. Replaced fuel filter. No effect.
3. Replaced spark plugs and wires. No effect - but when I was finished I didn't have a good connection on the number 5 cylinder. I ended up running on only five cylinders for about 5 minutes. I got NO engine codes from this which is amazing to me.
4. I figured that the oxygen sensor on the driver's side was out because of the lack of engine code. I replaced the front one which controls the air/fuel mixture. No effect.
5. I replaced the IAC valve. No effect.
I'm running out of ideas and the Dealership is of no help. YES, I AM GETTING GAS FROM DIFFERENT PLACES, SO IT IS NOT THAT.
Does anyone see value in replacing the rear driver's side O2 sensor? Could it be the fuel pump and what would be a good test for that?
Any help would be greatly appreciated.
