housefish17
- March 20, 2007
- '99 Explorer Sport
n00b here
Anywho, a little backstory
I have an amp that I wired wrong, so it doesn't turn off with my car, so I put a light switch in the power cable (as opposed to rewiring it correctly), to easily turn the amp off when i turn the car off. Well every once in a while I forget, and my battery dies, and I jump it and it works just fine
THis happened again recently, except when I went to get my car jumped, it wouldn't start, so I went and bought a new battery, put it in, tried to jump it and it still wouldn't start.
The starter was making a clicking noise, so I disconnected the bottom wire on the starter (i think the ground wire), and my car started without a jump. I reconnect the wire, the car starts again, drive it to work, and when I try to start it again it won't start. It hasn't been able to start for several days, whenever i turn the ignition, it makes the same clicking noise, but I can always jump it to start it.
Is this a battery, or alternator, or starter issue, and if you could give me some ways to tell if it's either of those issues
Thanks
Thanks
