Cat replacment needed - Where to get? | Ford Explorer Forums
Badspell68
NJ
97 XLT 5.0 AWD 4-Door
Can anyone recommend a discount suppler where I can get a replacement exhaust component? The pipe with the small CAT, just off the manifold, needs to be replaced and the prices I coming across are outrageous.
www.rockauto.com
I'm guessing you're looking at direct fit. Cheapest direct fit rockauto has is just under $190 for a Magnaflow. If you have a friend with a welder or a cheap shop you could get it done for less buying a universal and having it welded in.
When I had new cats put on Shamrock, the dealer got them locally, parts were $240 for (2) cats, so they paid $120 each somewhere... I know that doesn't tell you anything useful at all now that I've typed it out... :)
97 XLT AWD 5.0
Anyone have a diagram so that I can indicate that cat that I am referring to?
What is that Direct-fit Magnaflow, is it a whole replacement or a segment you weld in before the cat and what category would I look under to find it?
Ford > Explorer > Year > Exhaust > Cat
...I believe
The one I was referring to was for a 91-94 OHV. Not sure if pricing will be the same for you or not.
If I'm not mistaken the forum here also gets a discount at RockAuto. There is a thread somewhere about that...
