cd player removal | Ford Explorer Forums
cd player removal
Premierexplorer
Portland/Corvallis OR
2007 Eddie Bauer 4.6
Im trying to remove a pioneer cd player in my 92. I removed the upper and lower steering column trim but cant find what else to do. I have also removed the ash tray. How do I remove the middle dash piece near the radio?
Remove the....
You shouldn't have to remove the trim to get the cd player out since it's not the factory radio. What you have to do is get the little silver pullers that should have come with the new radio to pull the old radio out of the silver cage that it is inside of within the trim. You insert these into the little slots that are in the center of the left and right side of the radio. You should feel a little click to let you know they are seated. Then just simply pull back and the radio will slide out. If you don't have the pullers, I think you can get them at Walmart or any car stereo shop. Good luck! :thumbsup:
Thanks for the help
