8) Code 335: Verify KOER Codes
Code 335 indicates DPFE sensor is out of self-test range (2.
6-4.2 volts) and may be faulty. DPFE system can detect lack of
pressure in exhaust system. A garage exhaust ventilation system,
installed during KOEO SELF-TEST, may cause DPFE sensor to generate
Code 335. Remove exhaust ventilation system. Repeat KOEO SELF-TEST.
Service codes as necessary. If no codes are present during KOEO SELFTEST,
complete QUICK TEST. If Code 335 is present during KOEO SELFTEST,
go to next step.
9) Check DPFE Sensor Pressure Input Hose
Remove pressure feed tube from DPFE sensor. Inspect tube,
including DPFE inlet, for blockage. Repair if necessary, and repeat
QUICK TEST. If no blockage is found, go to next step.
10) Measure VREF Circuit Voltage
With ignition off, disconnect DPFE sensor wiring harness
connector. Turn ignition on. Measure voltage between VREF and SIG RTN
terminals at DPFE sensor wiring harness connector. If voltage is 4-6
volts, replace DPFE sensor and repeat QUICK TEST. If reading is not 4-
6 volts, go to CIRCUIT TEST C.
