377Z
- February 12, 2003
- Lemont, IL
- 1998 Explorer Sport
One more thought--I will never understand why Ford decided to use the M5R1 instead of the T-5. Not that I've had any problems with the M5R1, but mine does see rather light useage. Judging by the input/output shaft size the Mazda is FAR weaker. It also manages to be much larger somehow. The T-5 is one of the most widely used transmissions with TONS of gear ratios to select from, is smaller, lighter, and VERY easy to rebuild. Since its so common, it may have been cheaper to use, too. all that would have been needed was a dedicated bellhousing, flywheel, and TC adaptor. Its actually also a pretty slick shifting piece too.
Heck, it could be retrofitted to a 4.0 with some effort. A ~3/8" thick bell housing adaptor would be easy to make. Since the pilot bearing is in the flywheel and the flywheel pilots on the crank, you could have a corresponding flywheel spacer turned that would maintain the piloting relationship. The spacer thickness would need to correspond with where input shaft tip's final installed placement would be (easily added up from measurements). If you adapt a GM bellhousing, you could use existing & readily available slave cyl, fork, & TO bearing. A shop that deals with hydraulics could make a custom line that would connect the Ford m/c to the GM slave. Add AA T/C abaptor, and voila, 4.0/T-5 combo.
Sorry, I haven't shot ducks in a while.
