RLBurkett
- April 15, 2003
- New Germay, PA
- 2000 Mountaineer V8
I have a 2000 Mountaineer V8 and have started to have an intermittent charging problem.
Maybe this has been discussed before, but I haven't seen anything here.
This is what I have found:
When in park or neutral with engine running the voltmeter shows low voltage and battery charge indicator light is lit. This is at any engine speed.
If the trans is in reverse or drive the voltmeter shows normal and the charge indicator light goes out
When driving as long as I am accelerating both indicators are normal and all is well. As soon as the vehicle is coasting or under a reduced load the indicators both show no charging.
It appears that with no mechanical load on the engine the charging system is not working regardless of engine speed. With a mechanical load on the engine all is OK.
Has anyone seen this problem? It seems it may be a loose connection, bad ground, etc. but I haven't found anything yet.
Can anyone help with any ideas of where and what to look at?
Thanks,
Bob :redexp:
Thanks,
Bob :redexp:
