Cheap Lift??? | Ford Explorer Forums
Cheap Lift???
skatermania88
Austin, TX
92 Sport
Okay I decided I want to go with a 4" lift on my 92 Explorer. I've looked around and seen that there are a few different companies that make them. Anybody know where I can get one for the lowest price? Also will I need anything else, or will the extra stuff needed be shown on the website that I get the kit from?
Thanks
Please try using the search function. You will find that most normal questions have been answered countless times. This question included
Just put a 3 inc BL in. you will fit 33s
TheRookie is correct, every day we get the same questions over and over again which could be answered by doing a little leg work and hitting the old Search Button. That Being said before getting a lift you need to what the intended use will be... Are you just getting lift for on-road looks, or for actual off-road use? I mean getting the "Cheapest" lift possible is not going to cut it if you're trying to build an off-road rig... You can get away with overbuilding your ride, but underbuilding it can lead to costly future problems (repairs and broken parts).
