jaydez
- September 3, 2009
- Hartford County, CT
- 2005 XLT V6 4x4
The day before my wedding (Oct 13) my truck started to give me an error message on the Message Center. If I floor it ot accellerate into traffic or onto a highway with a short ramp, once the RPMS reach 5,000 The battery light will come on and the message center will flash "check charging system". I had the alternator tested at Autozone and they told me that the alternator failed the load test.
I have been keeping an eye on the voltage gauge since this started to happen and havent noticed it moving at all. Is this gauge a live read-out or is it a dummy gauge like the oil pressure? It does not move at all, even when I get the warning.
If it only happens over 5,000 RPM will I be ok for a while? Or should I replace the alternator ASAP? Why are there 2 kinds of alternators that appear in every search for my truck? One has a rear post + terminal, the other is a side post. I'm pretty sure I need the side post based on how mine looks and the fact that there is only a 1/4 inch of clearance between where the rear terminal would be and the valve cover.
Has anyone ever used BOSCH replacement alternators? They are the only one I can find that had a decent new price. I dont want this to turn into my only t-bird where I had to replace a refurbished aternator every year or 10,000 miles. That got old after the 4th one I had to do in a parking lot in the snow... Though I got it down to remove and install the new one in under 10 minutes.
