Check engine light and rough start when it starts | Ford Explorer Forums
MFC Explorer
Peabody MA
'00 XLT
Not sure if this is the right section but it seemed like the one that fit most.
About two weeks ago my check engine light came on I went and had the code read and the problem is a small vacuum leak. This leads me to two questions.
First, today I went to go for a ride down the street and my ex wouldnt start unless I gave it some gas and then would die as soon as I let off. I tried again and kept it revved up for about a minute or two and then she ran fine but idled low around 400rpm. Would the vacuum leak cause this or do I have another problem too?
And second, I want to try and find said leak. I dont have a smoke machine which makes it difficult is there anywhere that it is common for an ex to develop a vacuum leak? Or is there any other easy way to find it other than checking every line?
Any help or ideas is greatly appreciated.
Get a can of non flammable carburator cleaner and spray it around the running engine one small area at a time, hoses, especially where they connect and hang unsupported, injecter bases, intake mating surfaces, any place that might have a vacuum leak. Work slowly. When the engine revs up, you are in the right area, consentrate on that spot till you find the leak.
From past experience, it is probably a cracked hose, but this is not always true.
Ray
Thanks a bunch ill try that later today.
Replace upper and lower intake manifold gaskets - same exact symptoms I experienced, changed mine on 2000 Mountaineer 4.0 SOHC - about a 2 hour job - $22 in oem gaskets from dealer. Codes read 0171 & 0174
