Check engine light, but No Codes???? | Ford Explorer Forums
JT
Fall River, MA
'96 XLT Control Trac
Well just got back from my mechanic who ran the anylizer on my truck, the check engine light is on but its not turning back any codes, we ran all the diagnostic tests and nothing, so he cleared the codes. He's saying its probably a bad ground somewhere. Anyone else have this issue?
First off, did his scanner say if the MIL was on? My guess would be that it was an OEM OBD-II code and that he has a Generic OBD-II scanner. The OEM codes start out P1XXX, whereas the Generic codes are P0XXX. I've never had an OEM only code so I don't know how my scanner would react, however it will only read Generic OBD-II codes. I would think that it would say something to the effect "unrecognized code" or something like that rather than not read anything at all. I would have him try a different brand of scanner if the light comes on again. If the light is on, there is supposed to be a code.
He was using a Snap-On tools scanner, and it said no codes present. Since him resetting the codes the light has since come back on.
Since he is using a Snap On, I would like to think that it is capable of retrieving OEM and generic OBD-II codes. A couple of other guesses then, maybe it had a bad connection, or maybe he didn't specify the proper VIN if he had to enter it in. Since the light came back on, something is faulty that is setting it. Ask him to read them again, being sure to set the scanner properly. If it still comes back as no codes, don't let him clear the light! Ask him if he'll reimburse you if you pay to have another shop pull the codes and they are able to retrieve the code. If he will reimburse you, go back to him for the work once you know the code. If he won't consider letting the shop that does pull the code do the work and avoid the previous mechanic. Another thought is try Autozone. Some people here (I've forgotten their name again) have gotten Autozone to read the codes for no charge under the assumption that they would purchase whatever part it needed from them.
THe mechanic is a personal friend of mine lol, he is taking the truck in on thursday and looking it over for me, he is gonna try another shop's scanner and see what he gets.
Thanks
