bovine
- June 7, 2012
- Fort White FL
- 1994 ford explorer 4x4
Hey so about two week ago I got a check engine light come on and are like okay so I check all the fluids and such all good so I crank it back up and the battery is good the oil pressure is good so it nothing major then so I drive it to collage and back close to 50 miles everything stays normal the whole time temp is right where its normal is which now that it getting warmer is about the n maybe touching the o. so I get home and the next day since I don't have to go anywhere I attempt to pull the codes using the paper clip method and iIthink I got a code 33 but I'm not 100 percent sure on that one so i cleaned the EGR valve and had the batter cables off to reset the computer and it did not help at all with it still comes on and its not affecting anything that I can tell but since i have drove it probably around 150 miles or so with it on its just really annoying to have that light staring you in the face while your driving and i want it gone so i am posting videos to go with this so you can help me 1 figure out what codes are being thrown and 2 how to fix them.
here is key on engine off
here is key on engine on
Thanks for all the help.
