check engine light on a/con all the time and cycling | Ford Explorer Forums
norton2929
el dorado hills ca,
93 ford ranger xlt 4.0
i have 93 ford ranger 4.0 m/t 2 wd check engine light on. a/c stays on all the time and cycles switch on or switch off.ecm tells me a/c is on even when i pull the relay.ecm also telling my code reader that its a 4 cylander. do i have to replace ecm?
Welcome to the forum, if you post this in the tech section one of the members may be able to answer this for you.
