edman
- September 26, 2001
- Monsey, NY
- 96 Explorer Sport
Need some help my x has its check engine light on and it does not go off. The fault code I am getting is 1450. Not sure what exactly that means. I have the HAYES Ford Explorer manual and it does not refer tp this code. The closest it has is:
P0452 EVAP fuel tank pressure sensor low input
P0453 EVAP fuel tank pressure sensor high input
Where I had the check engine light read said that the code has to deal with air getting into the fuel tank. Not sure if that sounds right, has anyone out there had the same fault code if so what did you do? I know that there are a couple of sensors (fuel pressure regulator) or valves (Fuel Vapor Management Valve - VMV), cleaning the charcoal canister was even recommended. Before I go crazy testing and changing everything any advise?
Thanks
Thanks
