Check gas cap light ..... then P0457 appears 4 days later ? | Ford Explorer Forums
davem
Rochester, MN
'01 XLT
I have a 2001 XLT, V-6 4.0 SOHC with 149,000 miles.
My Check Gas Cap light came on, and then 4 days later, the check engine light came on, so I had toe code read: P0457 (seems like this points to gas cap).
I'm curious why the 2 'check' lights did not come on at the same time.
Could the P0457 indicate some other type of issue ?
ive got the same damn explorer with the same damn problem! lol let me know what you find!
After repairing the breakage at the top of the filler neck with JB weld, the problem continued.
So I finally caved and did what I should have done from the beginning - I put on a new fuel cap -a Stant for about $12. The problem has not returned over a month.
Once again reminding me: try the easy/cheap fix first.
