Checking transmission fluid level in 2016 Explorer sport! | Ford Explorer Forums
Bill McCall
Columbus, OH
2016 Sport
I'm 6'1 200lbs and can barely reach the cover for the transmission fluid port. I don't have enough grip to turn it. Wife's arms too short- Anyt tricks?
Pull out the air cleaner box that will give you more access.
Back off the 8mm (5/16") hose clamp at the filter cover, and remove the 2 8mm bolts holding the fresh air duct to the core support. Break the rubber hose loose, then pull the box straight up & out. While it's out, pull the filter & dump all the accumulated trash out of the bottom of the box.
