hey guys im new here i have a 96 4 door 4.0 ohv was wondering if anyone has used a gforce chip and if i could get pointed in the right direction on 2 to 3 inch lift
Its just a resistor to change your air/fuel ratio and most likely will cause you to run lean.
I only hear the best about the SCT Chips, and Hensen tunes, I will be getting myself hooked up next spring with them. A little more pricey, but I havent heard ONE bad thing about it.
ok tanks ill check out sct any tips on a small lift 2 or 3 inch i have 31x10.5 on it now would like to run a 32 or 33 with out any rubbing also should i change gears it has 3.73
