Tbruz
- June 16, 2013
- 2003 Exporer Sport
I've searched the existing threads on the cigarette lighter issues popping fuses but I think I need some additional help here.
I have a 2003 Explorer Sport that pops fuse #17 (20Amp) and takes out the OBD II connection if I try using the cigarette lighter.
I replaced the fuse and the OBD connection is fine IF I do not attempt to use the lighter.
Thinking the socket is bad I went ahead and replaced the lighter socket with a Dorman aftermarket lighter/socket( $5 versus the Ford ones at $40) but the fuse still pops if I push in the lighter to use it.
So either I have a bad Dorman socket/lighter or my problem is in the wires.
Thinking I can prove the socket/lighter assembly is good or bad by hooking it up directly to the battery and seeing if it works that way.
I do measure 12 V at the center post of the socket so I know the voltage is there before pushing in the lighter element.
I'm looking for a specific test/method to check the existing lighter wires out for shorts or bad ground??
It only two wires at the back side of the socket , how hard can this problem be
Thanks in advance
Tbruz
Thanks
Tbruz
Thanks in advance
Tbruz
Thanks
Tbruz
