cleaned MAF sensor today | Ford Explorer Forums
black crowe
louisville,ky
'92 EB
WOW! Big improvement, took care of most of the pinging too. I used electronic cleaner(forgot name already) "quick drying/no residue formula, worked great! Still have some pinging though. Im using 92 gas plus stp booster. Is that good too use with superchip? Is it possible too run too much octain?
It may also help the pingin to disconnect your batery for about thirty minutes to reset the computer. Make sure you put the gas in that you would like to run all of the time. Then reconnect your battery and drive. This should reset your computer to normal conditions.
There's no need to run octane booster with 92 (premium) gas. All it does is cause incomplete combustion and foul your injectors faster. It is a good idea to run injector cleaner every once in a while, but not if it's also octane booster.
The suggestion to reset your computer is a good one. After you reconnect the cable and drive the truck though, let it idle for 10-15 minutes with all accessories off.
