Cleaning fuel injectors | Ford Explorer Forums
mg655321
Danbury CT
94 XLT 4.0
After replacing my oxygen sensors (who's bright idea was it to put the connectors THERE?), checking fuel pressure and vacuum (both normal) I still have a problem running with a load on the engine (can't really run in overdrive until I get to 70) I've decided to rework my fuel rail. I shall replace the o-rings and clean the injectors. Is Gumout a good thing to soak them in?
Then I'm going to put them to my mouth, and test them with a battery to make sure they open and close.
This is the pushrod engine, the fuel rail work seems really easy from the Haynes manual, I can't see it taking me more than an hour to get the injectors out.
