clear out installation? | Ford Explorer Forums
Tony26Italy
Whats up
I'm getting clear outs for the front of my 94 sport tomorow for christmas....and i want to know how to install them before i try it out....can someone please help me with removing the old ones and putting in the new ones...i got them from Auto Syndicate if that is of any use
I'm also getting 9004 Xenon blue plasma bulbs...forgot the name but its something like that...anyway will all i have to do is take off the headlight cover, take out the old bulb and put the new one in?
Any help will be appreciated thanks guys...merry christmas too
I'm not sure about the clears but you don't have to take out the headlight to change the bulb. Reach behind the light and you'll feel and wiring harness and there is a plastic ring around it. Turn the ring and take it off. Then unplug the harness. Then you can pull the bulb out.
Steve
You don't have to undo the lights untill after the fixure is removed. first you'll notice (with the hood up) two small screws going into the head light. remove those. next carefully pry around the chrome on the headlight. the head light doen't come out with the fixture but all peices with orange does. you have to pull hard once you can get your fingers around it. it shouldn't brake. once it's out just unscreww and pop in the replacement lenses. putting it back on make sure you pound around the edges. so that it's tight again.
