Clearance Question | Ford Explorer Forums
Clearance Question
ntrpriz
Gilbert, AZ
2019 Ford Ranger Lariat
Callsign
N0FJC
I need a question answered. When you install a lift kit, you dont get any extra ground clearance to the pumpkins, right? The only clearance that is gained is by using larger tires and a lift kit allows larger tires than stock.
Thanks
Steven
Stock 94 XLT
PIAA Superwhites.
Vampire Alarm.
Jensen Head w stock Premium sound.
Radio Schack CB with magnetic mount antenna.
Uniden Scanner.
bingo steve.
Matt Adams
94 Explorer 4-door nick-named "Tippy"
http://bart.is-s.com/~explorers/explorer/explorer.html
Not between the wheels, but the body is higher off the ground. That'll improve the approach, departure and breakover angles, making it less likely to scrape or rip off items like bumpers, cats, muffler, tailpipes etc. when approaching and going over obstacles. Shorter wheelbases have the same effect, like in Jeep CJ and the like.
'99 Sport 4wd SOHC
[This message has been edited by Peter Weber (edited 04-01-2000).]
