OldTurtle
- August 10, 2018
- Cincinatti, OH
- 2004 Sport Trac XLT
I have a 2004 Sport Trac Adrenaline that sat idle all summer and the battery died. After jump starting it and driving around a bit to charge up the battery, an erratic clicking noise started up in the driver’s wheel well above the gas pedal. It continued to click even after the key was turned off and removed. I finally disconnected the battery.
When I reconnected, the battery was dead again. Replaced the battery with new, clicking back again. After digging around under the dash I found a relay block with 3 relays: 2 small black ones that were very hot to the touch and a blue square one. Found out that the blue one was the culprit and doing a Google search on part number, said it was for blinkers. Bought a new and installed, now it sounds like the blinkers are constantly blinking. With key removed I can turn on blinkers with lever. Black relays still quite hot. Disconnected new battery and now trying to figure next step.
Long dissertation, but I can’t find a post on here with the same problem, figured I’d better be specific. Any ideas?
