Clinks and then it makes a metal grinding noise | Ford Explorer Forums
MikeMike89
From Mebane NC, Just moved to Norfolk VA
93 4x4 Explorer
ok, so when i go around the block at 5 mph its fine. but when i i speed up to about 20 it clinks and then it makes a metal grinding noise coming from the rear. then when i stop for a second an go the process starts over agian. wtf?
rear Diff....
EFFFFFF.......for real man...
Well based on the limited info yeah maybe....
Does it go away over 20? Does it sound like grinding or just a metal on metal scrap such as a heat shield...
could be severely damaged u-joints, it happened in my camaro.
yeah, it sounds more like a heat shield scraping but it has drum brakes in the rear. and it dosnt do it at very low speeds
slave cylinder gone out on rear drum?
so i watited till it stopped raning and took it around the block a few times and the noise is gone? wtf....help?
Without actually hearing the noise, I would say to look for a binding/dragging brake shoe. Does it make any noise while backing up?
