gijoecam
Village Idiot
- May 31, 1999
- Trenton, MI
- 98 ExSport, '00 F-150
I know that the manual does state to remove the motor to get the pan off and had wondered if you can do it by dropping the front diff, but you would think that even with droppind the front diff being a PITA, it certainly would be better than removing the engine??? Why wouldn't the shop manual suggest that?
I'm not seeing that in the factory service manual... not sure what manual you're looking at, but here's what I'm seeing:
Oil Pan
Removal
On All Vehicles
1. Check vehicle ride height. For additional information, refer to «Section 204-05».
2. Raise and support the vehicle. For additional information, refer to «Section 100-02».
µ 3. Drain the engine oil and reinstall the drain plug.
4. Remove both front torsion bars. For additional information, refer to «Section 204-01A» (Front Suspension—4x2) or «Section 204-01B» (Front Suspension—4x4).
For 4WD Vehicles
µ 5. Disconnect the front driveshaft CV joint and position aside.
µ 6. Disconnect the axle vent tube.
µ 7. Support the axle with a suitable jack.
µ 8. Note:
Front driveshaft removed for clarity.
Remove the left front axle-to-frame bolt.
µ 9. Note:
Remove the two axle-to-frame bolts. Lower the axle to just rest on the lower control arms.
On All Vehicles
10. Remove the starter motor. For additional information, refer to «Section 303-06».
µ 11. Remove the bolts.
µ 12. Remove the bolts and the nuts.
µ 13. Remove the oil pan and the gasket.
Could it be that no matter what you can't get enough clearence to get the pump and sump off to get the pan off????
Has anyone removed the pan w/o taking the motor out?
I've heard that on *some* vehicles, it's sometimes possible to loosen all the pan bolts, drop the pan far enough to reach up in there, and remove the oil pickup bolts and just drop the pickup into the pan and slide it out. Not sure if you'll be able to do that with a 4.0 OHV or not... Never tried it myself.
