danohagen
- March 6, 2005
- los angeles
- 94 limited
Last February, I started getting a Check Engine Light (CEL) on my 1994 Ford Explorer V-6; so I thought as in the past, it’s probably the Oxygen Sensors being that they haven’t been changed in about 80,000 miles. Changed them (2) out and still get the CEL light
. I ran the OBD1 Codes and came up with Code 176HEGO (H20S) Sensor Fault Always LEAN.
The light scenario is daily. It goes on after the engine heats up between 2 to 3 miles of driving. There is no adverse or noticeable problem in the engine performance. In fact, I’m getting pretty good gas milage.
In March, I was getting irritated with the CEL light, so I changed out the 1) EGR DPFE Position Sensor Valve, 2) Vacuum Regulator Solinoid for the EGR Valve, 3) The EGR valve, 4) Fuel Injection Cleaning, 5) PCV Valve, 6) Spark Plugs and Wires
Of course now I’m saying that the Explorer probably needed these parts anyway since I fixed everything but the problem. I still get Code 176HEGO (H20S) Sensor Fault Always LEAN :fire: .
OK, now I’m humbled
and appeal to all you Garage Mechanics. What do you think the problem is or what would you try next?
Dan
OK, now I’m humbled
Dan
