RickMar
- April 11, 2009
- N. Andover Massachusetts
- 99 Mercury Mountaineer
Hi;
Thank you for taking the time to read this thread.
I have a 1999 Murcury Mountaineer.
I had the state inspection on Mounty and it failed emissions.
Code P0442 put an end to the inspection and a big "R" sticker is on the windshield.
Code P0442 is Gas Cap, Vacuum leak or purge valve.
Figuring the gas cap and vacuum leak aren't too difficult to fix, I replaced the Purge Valve located under the battery box.
I read something somewhere in this forum and I can not locate it which explained something about driving the mounty a certain way at different speeds stopping then accelerating
to 45 M.P.H. / 60 M.P.H. and letting it coast down to a stop.
I am not sure how it went exactly.
My question is ...Although the check engine light is out, do I need to go through any driving procedure to clear out the code P0442?
Any information will be very much appreciated.
Thank you;
Rick
Thank you;
Rick
