code p0442 - what steps to take? | Ford Explorer Forums
bryanhbre
Elkhart, IN
2001 mountaineer
our 01 mountaineer recently had the check engine light come on. 96K miles, never had the light on since we've owned it (around late 2006). Took it to autozone & had them read the codes, only showed p0442, which is some sort of evap emissions control thing. Took off the gas cap and reset it, then disconnected the battery & cleared the codes. No codes for a week, then today the light came back on again. Should I try a new gas cap? If that doesn't fix it, what would be a good place to start from there?
First I would check all the vac hoses under the hood, look for splits, cracks and such. Then the gas cap is probably a good bet. It would be nice to check it on a smoke machine, but those things are too expensive for a casual mechanic. The gas cap is cheap enough to quess at.
