coil spacer problem | Ford Explorer Forums
coil spacer problem
tac0meat
91 EB 2x4
i need to get some new tires and im wanting to up the size, but in order to do that i need to get my front end lifted, i tried to put coil spacers on a while back, but couldnt make it work so i boxed them up and put the spacers aside. well, now i need to get them on to fit the bigger tires. heres the problem: the bolts are too short to accomdate the spacers, where can i get longer bolts?
You will need to get the bolt from a 4*4 model. When I had my 2 wd this is how I got around this. Hope this helps.
where can i get a the 4*4 bolt? do you think i could order one through ford parts network?
