gijoecam
Village Idiot
- May 31, 1999
- Trenton, MI
- 98 ExSport, '00 F-150
The PCM and the IAC valve can't control the airflow if the breather is clogged preventing air from entering. Ford should have identified cleaning or replacement of the IAC valve air filter at some interval just like was done for the main air filter.
Air is not drawn through that cap (and if it is, there's something else wrong). Air entering the system there would be both un-metered and un-filtered.
Well, unfortunately removing the cap didn't make much difference. But the ordered parts are coming this week.
I wouldn't expect it to.
Well, I replaced the old part with the new IAC-valve. When I crancked the engine I noticed that the startup flare was about 2000 rpm in stead of 2500/2600 rpm. It did however still have a shakey idle, but it didn't die.
I had already noticed (with the old part as well as with the new part) that when you first drive off you have to push the gaspedal till about 1500/1700 rpm and after that you can release the gaspedal and you will continue driving with about 1000 - 1400 rpm. At the first traffic light or stop (let's say 50 - 500 meters) the idle will drop to about 1000 rpm and then to about 750 rpm. The first time the idle reaches 750 rpm it will still be a bit shakey, but it doesn't die.
The outside temperature has been above freezing point (about 2 - 5 degrees celsius) the last week, so this probably plays a role as well.
Do these symptoms still match leaky air intake manifold gaskets?
Next week I'm scheduling an apointment for replacing them (upper and lower).
That sounds like a vacuum leak, but it sounds like a more severe leak than just a gasket. I'd be looking for a vacuum hose leak somewhere in addition to the intake manifold gaskets that likely need to be replaced anyways.
