dcotter
- May 22, 2001
- johnstown, pa
- 1994 explorer xlt
Can anyone tell me where the sensor is that tells the computer that the engine is cold or warm? When I try to start my 94 explorer xlt when warm it is floodinig itself and runs rich until it gets back up to normal operating temp. If I let it sit for about 4 hours or more then it seems to start fine. Otherwise it is very difficult to start and once started it is very rich until the temp gage gets up to where it usually runs at. Help???? If you are thinking the injectors are leaking, they are not. They held pressure with engine off for quite some time. I checked it with a fuel pressure gage and at idle I have 35psi. After I shut it off it drops to about 32 and holds. I've replaced the relay, regulator and pump. No change. It also seems to have gotten progressivly worse.
